Detection and resolution of aspect interactions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
Rémi Douence
Mario Südholt
Aspect-Oriented Programming (AOP) promises separation of concerns at the implementation level. However, aspects are not always orthogonal and aspect interaction is an important problem. Currently there is almost no support for the detection and resolution of such interactions. The programmer is responsible for identifying interactions between conflicting aspects and implementing conflict resolution code. In this paper, we propose a solution to this problem based on a generic framework for AOP. The contributions are threefold: we present a formal and expressive crosscut language, two static conflict analyses and some linguistic support for conflict resolution.
Autre [cs.OH]
RR-4435.pdf (286.88 Ko) Télécharger le fichier
inria-00072153 , version 1 (23-05-2006)
  • HAL Id : inria-00072153 , version 1
Rémi Douence, Pascal Fradet, Mario Südholt. Detection and resolution of aspect interactions. [Research Report] RR-4435, INRIA. 2002. ⟨inria-00072153⟩
251 Consultations
417 Téléchargements
