Simulation Results of the OLSR Routing Protocol for Wireless Network - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
Paul Mühlethaler
  • Fonction : Auteur
  • PersonId : 833453
Epiphane Plakoo
  • Fonction : Auteur
In this research report, we present simulation results for the Optimized Link State Routing protocol: «OLSR». «OLSR» is a routing protocol currently submitted at the IETF in the Mobile Ad-hoc NETwork workgroup. «OLSR» is a proactive protocol, thus it periodically sends «control» packets to build and up-date the topolgy. The aim of this article is to study the performance of the OLSR protocol. Although most of the results that we show remain valid for any kind of above medium access control and physical layer, the simulation results were obtained with an IEEE 802.11 medium access control and physical layer. The key parameters that we evaluate in this article, include: the overhead incurred by the routing protocol, the percentage of packets lost in the control packets and the lack of routes due to control packet loss. We also study the benefit of a genuine optimization of the «OLSR» protocol: the multipoint relay optimization. We test the «OLSR» capability to support mobility.
Autre [cs.OH]
RR-4414.pdf (485.95 Ko) Télécharger le fichier
inria-00072174 , version 1 (23-05-2006)
  • HAL Id : inria-00072174 , version 1
Anis Laouti, Paul Mühlethaler, Abdellah Najid, Epiphane Plakoo. Simulation Results of the OLSR Routing Protocol for Wireless Network. [Research Report] RR-4414, INRIA. 2002. ⟨inria-00072174⟩
210 Consultations
794 Téléchargements
