New formulas around Laplace transforms of quadratic forms for general Gaussian sequences - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
Various methods to derive new formulas for the Laplace transforms of some quadratic forms of Gaussian sequences are discussed. In the general setting, an approach based on the resolution of an appropriate auxiliary filtering problem is developed; it leads to a formula in terms of the solutions of Voterra type recursions describing characteristics of the corresponding optimal filter. In the case of Gauss-Markov sequences, where the previous equations reduce to ordinary forward recursive equations, an alternative approach provides another formula; it involves the solution of a backward recursive equation. Comparing the different formulas for the Laplace transform- s, various relationships between the corresponding entries are identified. In particular relationships between the solutions of matched forward and backward Riccati equations are thus proved probabilistically; they are proved again directly. In various specific cases, a further analysis of the concerned equations leads to completely explicit formulas for the Laplace transform.
RR-4357.pdf (280.29 Ko) Télécharger le fichier
inria-00072231 , version 1 (23-05-2006)
  • HAL Id : inria-00072231 , version 1
Marina Kleptsyna, Alain Le Breton, Michel Viot. New formulas around Laplace transforms of quadratic forms for general Gaussian sequences. [Research Report] RR-4357, INRIA. 2002. ⟨inria-00072231⟩
126 Consultations
237 Téléchargements
