Chromatic Variants of the Erdös-Szekeres Theorem on Points in Convex Position - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2002
Olivier Devillers
Ferran Hurtado
  • Fonction : Auteur
Carlos Seara
  • Fonction : Auteur
Let S be a point set in the plane in general position, such that its elements are partitioned into k classes or colors. In this paper we study several variants on problems related to the Erdös-Szekeres Theorem about subsets of S in convex position, when additional chromatic constraints are considered.
Autre [cs.OH]
RR-4352.pdf (263.23 Ko) Télécharger le fichier
inria-00072236 , version 1 (23-05-2006)
  • HAL Id : inria-00072236 , version 1
Olivier Devillers, Ferran Hurtado, Carlos Seara. Chromatic Variants of the Erdös-Szekeres Theorem on Points in Convex Position. RR-4352, INRIA. 2002. ⟨inria-00072236⟩
60 Consultations
192 Téléchargements
