Elasticity on a Thin Shell: Formal Series Solution - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
The three-dimensional equations of elasticity are posed on a domain of R^3 defining a thin shell of thickness 2ε. The traction free conditions are imposed on the upper and lower faces together with the clamped boundary conditions on the lateral boundary. After a scaling in the transverse variable, the elasticity operator admits a power series expansion in with intrinsic coefficients with respect to the mean surface of the shell. This leads to define a formal series problem in associated with the three-dimensional equations. The main result is the reduction of this problem to a formal series boundary value problem posed on the mean surface of the shell.
Autre [cs.OH]
RR-4349.pdf (441.51 Ko) Télécharger le fichier
inria-00072239 , version 1 (23-05-2006)
  • HAL Id : inria-00072239 , version 1
Erwan Faou. Elasticity on a Thin Shell: Formal Series Solution. [Research Report] RR-4349, INRIA. 2002. ⟨inria-00072239⟩
141 Consultations
141 Téléchargements
