Design and Comparison of Lattices of Topological Relations for Spatial Representation and Reasoning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2001
Florence Le Ber
Ludmila Mangelinck
  • Fonction : Auteur
  • PersonId : 756515
  • IdRef : 190757809
Amedeo Napoli
This report presents an original approach to spatial representation and reasoning with topological relations based on the use of lattices of relations- . This approach has been developed for spatial reasoning in the domain of agricultural landscape analysis. The report describes first the motivation of the present research work and the general framework of topological relations. Four different lattices of topological relations, including Galois lattices, are introduced. The choices made for spatial representation and reasoning with these lattices are discussed, together with a thorough study and comparison of the four lattices. The implementation of one of the lattices within an object-based representation system, as well as spatial lattice-based reasoning with topological relations in this system are then detailed.
RR-4321.pdf (668.99 Ko) Télécharger le fichier
inria-00072266 , version 1 (23-05-2006)
  • HAL Id : inria-00072266 , version 1
Florence Le Ber, Ludmila Mangelinck, Amedeo Napoli. Design and Comparison of Lattices of Topological Relations for Spatial Representation and Reasoning. [Research Report] RR-4321, INRIA. 2001, pp.57. ⟨inria-00072266⟩
68 Consultations
225 Téléchargements
