Parameter Identification for Laplace Equation and Approximation in Hardy Classes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2001
M. Jaoua
  • Fonction : Auteur
Juliette Leblond
  • Fonction : Auteur
  • PersonId : 833419
We consider the inverse problem of identifying a Robin coefficient on some part of the boundary of a smooth 2D domain from overdetermined data available on the other part of the boundary, for Laplace equation in the domain. Using tools from complex analysis and analytic functions theory, we provide a constructive and convergent identification scheme for this inverse problem, together with numerical experiments.
Autre [cs.OH]
RR-4295.pdf (712.81 Ko) Télécharger le fichier
inria-00072292 , version 1 (23-05-2006)
  • HAL Id : inria-00072292 , version 1
S. Chaabane, M. Jaoua, Juliette Leblond. Parameter Identification for Laplace Equation and Approximation in Hardy Classes. RR-4295, INRIA. 2001. ⟨inria-00072292⟩
78 Consultations
228 Téléchargements
