Sensitivity Analysis for an Incompressible Aeroelastic System - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2001
This article deals with problems arising in the sensitivity analysis for fluid-structure interaction systems. Our model consists of a fluid described by the incompressible Navier-Stokes equations interacting with a solid under large deformations. We obtain a linearized problem which allow us to compute the derivative of the state variable with respect to a given boundary parameter. We use a particular deflinition of the first-order correction for the perturbed state and consider a weak Arbitrary Euler-Lagrang- e formulation for the coupled system.
RR-4264.pdf (297 Ko) Télécharger le fichier
inria-00072323 , version 1 (23-05-2006)
  • HAL Id : inria-00072323 , version 1
Miguel Angel Fernández, Marwan Moubachir. Sensitivity Analysis for an Incompressible Aeroelastic System. [Research Report] RR-4264, INRIA. 2001. ⟨inria-00072323⟩
73 Consultations
217 Téléchargements
