Visual Servoing from Lines - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2001
In this work, we present a fundamentally new approach to visual servoing using lines. It is based on a theoretical and geometrical study of the main line representations which allowed us to define a new representation, the so-called binormalized Plücker coordinates. They are particularly well suited to visual servoing. Indeed, they allow the definition of a proper image line alignment notion. The control law which realizes such an alignment has moreover several properties: partial decoupling between rotation and translation, analytical inversion of the motion equations and global asymptotic stability conditions. This control law was validated both in simulation and experimentally in the specific case of an orthogonal trihedron.
Autre [cs.OH]
RR-4226.pdf (595.06 Ko) Télécharger le fichier
inria-00072393 , version 1 (24-05-2006)
  • HAL Id : inria-00072393 , version 1
Nicolas Andreff, Bernard Espiau, Radu Horaud. Visual Servoing from Lines. [Research Report] RR-4226, INRIA. 2001. ⟨inria-00072393⟩
248 Consultations
177 Téléchargements
