SCILAB to SCILAB// - The Ouragan Project - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2001
Martin Quinson
Frédéric Suter
Eddy Caron
Dominique Lazure
  • Fonction : Auteur
  • PersonId : 1154826
  • IdRef : 069843112
Gil Utard
In this paper, we present the developments realized in the OURAGAN project around the parallelization of a MATLAB-like tool called SCILAB. These developments use high performance numerical libraries and different approaches based either on the duplication of SCILAB processes or on computational servers. This tool, SCILAB, allows users to perform high leveloperations on distributed matrices in a metacomputing environment. We also present performance results on different architectures.
RR-4203.pdf (332.88 Ko) Télécharger le fichier
inria-00072419 , version 1 (24-05-2006)
  • HAL Id : inria-00072419 , version 1
Frédéric Desprez, Martin Quinson, Frédéric Suter, Eric Fleury, Emmanuel Jeannot, et al.. SCILAB to SCILAB// - The Ouragan Project. [Research Report] RR-4203, INRIA. 2001. ⟨inria-00072419⟩
402 Consultations
897 Téléchargements
