Lyapunov Exponents: When the Top joins the Bottom - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2001
In this paper, we consider Lyapunov exponents associated with iterates of random functions. When these functions are taken from an irreducible set, we show that the top and the bottom Lyapunov exponents are equal.
Autre [cs.OH]
RR-4198.pdf (207.88 Ko) Télécharger le fichier
inria-00072424 , version 1 (24-05-2006)
  • HAL Id : inria-00072424 , version 1
Dohy Hong. Lyapunov Exponents: When the Top joins the Bottom. [Research Report] RR-4198, INRIA. 2001. ⟨inria-00072424⟩
118 Consultations
162 Téléchargements
