On the Fluid Limits of Some Loss Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2001
Christine Fricker
  • Fonction : Auteur
  • PersonId : 831323
Philippe Robert
Danielle Tibi
  • Fonction : Auteur
We study the fluid limits of loss networks under Kelly's scaling. In the case of heavy traffic for a single node and J classes of calls, we prove a degenerate diffusion approximation theorem around the corresponding fluid limit. After a careful analysis of some reflected random walks in N, we prove that Hunt and Kurtz's conjecture (1994) for the trunk reservation policy is wrong. We conclude with some remarks on the conjecture in the case of an uncontrolled network.
Autre [cs.OH]
RR-4171.pdf (308.08 Ko) Télécharger le fichier
inria-00072451 , version 1 (24-05-2006)
  • HAL Id : inria-00072451 , version 1
Christine Fricker, Philippe Robert, Danielle Tibi. On the Fluid Limits of Some Loss Networks. [Research Report] RR-4171, INRIA. 2001. ⟨inria-00072451⟩
86 Consultations
118 Téléchargements
