Splitting a Delaunay Triangulation in Linear Time - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2001
Olivier Devillers
Ferran Hurtado
  • Fonction : Auteur
Mercè Mora
  • Fonction : Auteur
Vera Sacristán
  • Fonction : Auteur
Monique Teillaud
Computing the Delaunay triangulation of $n$ points requires usually a minimum of $\Omega(n\log n)$ operations, but in some special cases where some additional knowledge is provided, faster algorithms can be designed. Given two sets of points, we prove that, if the Delaunay triangulation of all the points is known, the Delaunay triangulation of each set can be computed in randomized expected linear time.
Autre [cs.OH]
RR-4160.pdf (227.69 Ko) Télécharger le fichier
inria-00072462 , version 1 (24-05-2006)
  • HAL Id : inria-00072462 , version 1
Bernard Chazelle, Olivier Devillers, Ferran Hurtado, Mercè Mora, Vera Sacristán, et al.. Splitting a Delaunay Triangulation in Linear Time. RR-4160, INRIA. 2001. ⟨inria-00072462⟩
70 Consultations
470 Téléchargements
