Performance Evaluation of a Single Queue under Multi-User TCP/IP Connections - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2001
Cédric Adjih
Philippe Jacquet
We study the performance of several TCP connections through the bottleneck of a slow network accessed via a single queue with high capacity. Using mean-field approximation methology, we establish some asymptotical results about queue length distribution and windo size distribution when the number of user increases proportionally to buffer capacity. We also give an evaluatio- n of TCP fairness under these traffic conditions.
Autre [cs.OH]
RR-4141.pdf (474.79 Ko) Télécharger le fichier
inria-00072484 , version 1 (24-05-2006)
  • HAL Id : inria-00072484 , version 1
Cédric Adjih, Philippe Jacquet, Nikita Vvedenskaya. Performance Evaluation of a Single Queue under Multi-User TCP/IP Connections. [Research Report] RR-4141, INRIA. 2001. ⟨inria-00072484⟩
115 Consultations
119 Téléchargements
