Additive Symmetric: the Non-Negative Case - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Theoretical Computer Science Année : 2003
Marc Daumas
  • Fonction : Auteur
Philippe Langlois
An additive symmetric b of a with respect to c satisfies c = (a+b)/2. Existence and uniqueness of such $b$ are basic properties in exact arithmetic that fail when a and b are floating point numbers and the computation of $c$ performed in IEEE-754 like arithmetic. We exhibit and prove conditions on the existence, the uniqueness and the exact correspondence of an additive symmetric when b and c have the same sign.
Autre [cs.OH]
RR-4115.pdf (270.41 Ko) Télécharger le fichier
inria-00072516 , version 1 (24-05-2006)
Marc Daumas, Philippe Langlois. Additive Symmetric: the Non-Negative Case. Theoretical Computer Science, 2003, 291 (2), pp.143-157. ⟨10.1016/S0304-3975(02)00223-2⟩. ⟨inria-00072516⟩
66 Consultations
122 Téléchargements
