A New Formulation for Non-Linear Camera Calibration Using Virtual Visual Servoing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2001
Eric Marchand
This paper presents a new formulation for the non-linear calibration problem. We propose a method based on the well known visual servoing approach. We consider pose computation and lens calibration as the dual problem of visual servoing. It allows to take advantage of all the research that have been carried out in this domain in the past. The proposed method features accuracy, efficiency, scalability wrt. to the camera model as well as wrt. to the features extracted from the image, and simplicity.
Autre [cs.OH]
RR-4096.pdf (454.6 Ko) Télécharger le fichier
inria-00072535 , version 1 (24-05-2006)
  • HAL Id : inria-00072535 , version 1
Eric Marchand, François Chaumette. A New Formulation for Non-Linear Camera Calibration Using Virtual Visual Servoing. [Research Report] RR-4096, INRIA. 2001. ⟨inria-00072535⟩
237 Consultations
459 Téléchargements
