Distribution of Busy Period in Stochastic Fluid Models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2000
We consider the busy period in a stochastic fluid flow model with infinite buffer where the input and output rates are controlled by a finite homogeneous Markov process. We derive an explicit expression for the distribution of the busy period and we obtain an algorithm to compute it which exhibits nice numerical properties.
Autre [cs.OH]
RR-4057.pdf (275.59 Ko) Télécharger le fichier
inria-00072579 , version 1 (24-05-2006)
  • HAL Id : inria-00072579 , version 1
Nelly Barbot, Bruno Sericola, Miklós Telek. Distribution of Busy Period in Stochastic Fluid Models. [Research Report] RR-4057, INRIA. 2000. ⟨inria-00072579⟩
172 Consultations
236 Téléchargements
