A Coq Formalization of a Type Checker for Object Initialization in the Java Virtual Machine - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2000
Yves Bertot
We worked on a type system proposed in [11] to enforce a discipline for object initialization in the Java Virtual Machine language, to show how this type system could be implemented in the Coq proof and specification language. We used this description both to prove the theorems of [11] and to construct an effective verifier for this discipline.
Autre [cs.OH]
RR-4047.pdf (439.98 Ko) Télécharger le fichier
inria-00072591 , version 1 (24-05-2006)
  • HAL Id : inria-00072591 , version 1
Yves Bertot. A Coq Formalization of a Type Checker for Object Initialization in the Java Virtual Machine. [Research Report] RR-4047, INRIA. 2000, pp.53. ⟨inria-00072591⟩
76 Consultations
173 Téléchargements
