s'authentifier
version française rss feed
inria-00072595, version 1
On-The-Fly Range Reduction
Vincent Lefèvre a12, Jean-Michel Muller b1
N° RR-4043 (2000)
Résumé : In several cases, the input argument of an elementary function evaluation is given bit-serially, most significant bit first. We suggest a solution for performing the first step of the evaluation (namely, the range reduction) on the fly: the computation is overlapped with the reception of the input bits. This algorithm can be used for the trigonometric functions sin, cos, tan as well as for the exponential function.
  • Domaine : Informatique/Autre
  • Mots-clés : RANGE REDUCTION / ELEMENTARY FUNCTIONS / COMPUTER ARITHMETIC
  • Référence interne : RR-4043
  • inria-00072595, version 1
  • oai:hal.inria.fr:inria-00072595
  • Contributeur :
  • Soumis le : Mercredi 24 Mai 2006, 10:21:38
  • Dernière modification le : Mardi 7 Octobre 2008, 16:02:56
tous les articles de la base du CCSd...
