Blind subspace-based eigenstructure identification under nonstationary excitation using moving sensors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2000
Subspace identification algorithms have proven efficient for performing output-only identification of the eigenstructure of a linear MIMO system subject to uncontrolled, unmeasured, and nonstationary excitation. Such a problem arises in mechanical engineering, for modal analysis of vibrating structures and machines. A common practice there is to collect data from varying sensor locations, using both fixed and moving sensors, in order to mimic the availability of a larger set of sensors. The purpose of this paper is to investigate how subspace-based identification can be adapted to handle such a situation, to prove its consistency under nonstationary excitation, and to report on a real application example.
RR-4024.pdf (316.5 Ko) Télécharger le fichier
inria-00072616 , version 1 (24-05-2006)
  • HAL Id : inria-00072616 , version 1
Laurent Mevel, Albert Benveniste, Michèle Basseville, Maurice Goursat. Blind subspace-based eigenstructure identification under nonstationary excitation using moving sensors. [Research Report] RR-4024, INRIA. 2000. ⟨inria-00072616⟩
167 Consultations
218 Téléchargements
