Queueing Analysis of Simple FEC Schemes for IP Telephony - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2000
In interactive voice applications, FEC schemes are necessary for the recovery from lost packets. These schemes need to be simple with a light coding and decoding overhead so as not to impact the interactivity. The objective of this paper is to study a well known simple FEC scheme that has been proposed and implemented, in which for every packet $n$, some redundant information is added to some subsequent packet $n + \phi$. If packet $n$ is lost, it will be reconstructed in case packet $n+\phi$ is well received. The quality of the reconstructed copy of packet $n$ will depend on the amount of information of packet $n$ carried by packet $n+\phi$. We propose a detailed queueing analysis based on a ballot theorem, and obtain simple expressions for the audio quality as a function of the amount of redundancy and its relative position with respect to the original information. For a utility function that is linear in the amount of information, the analysis shows that this FEC scheme does not scale well and any amount of added redundancy might cause a degradation in the overall quality. We then introduce and analyze other utility functions in order to obtain a quality function that is better adapted to the characteristics of this kind of applications.
Autre [cs.OH]
RR-3998.pdf (535.07 Ko) Télécharger le fichier
inria-00072647 , version 1 (24-05-2006)
  • HAL Id : inria-00072647 , version 1
Eitan Altman, Chadi Barakat, Victor Manuel Ramos Ramos. Queueing Analysis of Simple FEC Schemes for IP Telephony. [Research Report] RR-3998, INRIA. 2000, pp.34. ⟨inria-00072647⟩
88 Consultations
221 Téléchargements
