inria-00072662, version 1
Smooth Surface Reconstruction via Natural Neighbour Interpolation of Distance Functions
Jean-Daniel Boissonnat
1Frederic Cazals
1
N° RR-3985 (2000)
Résumé : We present an algorithm to reconstruct smooth surfaces of arbitrary topology from unorganised sample points and normals. The method uses natural neighbour interpolation, works in any dimension and allows to deal with non uniform samples. The reconstructed surface is a smooth manifold passing through all the sample points. This surface is implicitly represented as the zero-set of some pseudo-distance function. It can be meshed so as to satisfy a user-defined error bound. Experimental results are presented for surfaces in R^3.
- 1 : PRISME (INRIA Sophia Antipolis)
- INRIA
- Domaine : Informatique/Autre
- Mots-clés : COMPUTATIONAL GEOMETRY – VORONOI DIAGRAMS – NATURAL NEIGHBOR INTERPOLATION – SURFACE RECONSTRUCTION
- Référence interne : RR-3985
- inria-00072662, version 1
- http://hal.inria.fr/inria-00072662
- oai:hal.inria.fr:inria-00072662
- Contributeur : Rapport De Recherche Inria
- Soumis le : Mercredi 24 Mai 2006, 10:31:27
- Dernière modification le : Jeudi 6 Novembre 2008, 15:42:58
Documents associés
Exporter
