Generalized Correlation Ratio for Rigid Registration of 3D Ultrasound with MR Images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2000
Xavier Pennec
Grégoire Malandain
Nicholas Ayache
Automatic processing of 3D ultrasound (US) is of great interest for the development of innovative and low-cost computer-assisted surgery tools. In this paper, we present a new image-based technique to rigidly register intra-operative 3D US with pre-operative Magnetic Resonance (MR) data. Automatic registration is achieved by maximization of a similarity measure that generalizes the correlation ratio (CR). This novel similarity measure has been designed to better take into account the nature of US images. A preliminary cross-validation study has been carried out using a number of phantom and clinical data. This indicates that the worst registration errors are of the order of the MR image resolution.
Autre [cs.OH]
RR-3980.pdf (779.17 Ko) Télécharger le fichier
inria-00072667 , version 1 (24-05-2006)
  • HAL Id : inria-00072667 , version 1
Alexis Roche, Xavier Pennec, Grégoire Malandain, Nicholas Ayache, Sébastien Ourselin. Generalized Correlation Ratio for Rigid Registration of 3D Ultrasound with MR Images. [Research Report] RR-3980, INRIA. 2000, pp.24. ⟨inria-00072667⟩
107 Consultations
303 Téléchargements
