Speeding up the Division and Square Root of Power Series - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2000
Guillaume Hanrot
  • Fonction : Auteur
  • PersonId : 831392
Michel Quercia
  • Fonction : Auteur
We present new algorithms for the inverse, quotient, or square root of power series. The key trick is a new algorithm -- RecursiveMiddleProduct or RMP -- computing the $n$ middle coefficients of a $2n x n$ product in essentially the same number of operations -- $K(n)$ -- than a full $n x n$ product with Karatsuba's method. This improves previous work of Mulders, Karp and Markstein, Burnikel and Ziegler. These results apply both to series, polynomials, and multiple precision floating-point numbers.
Autre [cs.OH]
RR-3973.pdf (332.55 Ko) Télécharger le fichier
inria-00072675 , version 1 (24-05-2006)
  • HAL Id : inria-00072675 , version 1
Guillaume Hanrot, Michel Quercia, Paul Zimmermann. Speeding up the Division and Square Root of Power Series. [Research Report] RR-3973, INRIA. 2000, pp.20. ⟨inria-00072675⟩
294 Consultations
719 Téléchargements
