Averaging of Non-Self Adjoint Parabolic Equations with Random Evolution (Dynamics) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2000
The averaging problem for convection-diffusion non-stationary parabolic operator with rapidly oscillating coefficients is studied. Under the assumptio- n that the coefficients are periodic in spatial variables and random stationar- y in time and that they possess certain mixing properties, we show that in appropriate moving coordinates the measures generated by the solutions of original problems converge weakly to a solution of limit stochastic PDE. The homogenized problem is well-posed and defines the limit measure uniquely.
Autre [cs.OH]
RR-3951.pdf (338.85 Ko) Télécharger le fichier
inria-00072698 , version 1 (24-05-2006)
  • HAL Id : inria-00072698 , version 1
Marina Kleptsyna, Andrey Piatnitski. Averaging of Non-Self Adjoint Parabolic Equations with Random Evolution (Dynamics). [Research Report] RR-3951, INRIA. 2000, pp.32. ⟨inria-00072698⟩
107 Consultations
65 Téléchargements
