Dynamic Optimisation of a Long Term Growth Rate for a Mixed Portfolio with Transaction Costs. The Logarithmic Utility Case - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1999
This paper studies the optimal investment policy for an investor who has available one bank account with fixed interest rate and n risky assets whose prices are log-normal diffusions. Transactions between the assets incur proportional transaction costs. The objective is to maximize the long run average growth of wealth for a logarithmic utility function. This problem is formulated as a singular stochastic control problem with ergodic criterion and interpreted as the limit of a discounted control problem when the discount factor goes to zero. The dynamic programming variational inequalities for the discounted control problem and the the limiting ergodic problem are established in the viscosity sense. The "potentia- l function'' for the ergodic problem can be obtained as a limit of the value function of the discounted problem when the discount factor goes to zero. The ergodic variational inequality is solved by using a numerical algorithm based on policies iterations and multigrid methods. A numerical example is displayed for 2 risky assets.
RR-3626.pdf (451.86 Ko) Télécharger le fichier
inria-00073050 , version 1 (24-05-2006)
  • HAL Id : inria-00073050 , version 1
Marianne Akian, Agnès Sulem, Michael I. Taksar. Dynamic Optimisation of a Long Term Growth Rate for a Mixed Portfolio with Transaction Costs. The Logarithmic Utility Case. [Research Report] RR-3626, INRIA. 1999. ⟨inria-00073050⟩
148 Consultations
133 Téléchargements
