Analysis of TCP in Networks with Small Buffering Capacity and Large Bandwidth-Delay Product - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1998
It is well known that inefficiencies occur in the operation of TCP when the bandwidth delay product of the network is large compared to its buffering capacity. A central reason for that is a cyclic behavior of the protocol in which two consecutive slow-start phases appear in each cycle [5,1]. This results in low throughput and under-utilization of the available bandwidth. We show in this paper that, for an even larger ratio between the bandwidth-delay product and the buffer size, which is typical for satellite links, a new regime of three consecutive slow-start phases occurs. We need to refine previously studied models in order to explain this phenomeno- n. We analyze in this paper this phenomenon, predict when it occurs and evaluate the corresponding average throughput of the connection.
Autre [cs.OH]
RR-3574.pdf (210.73 Ko) Télécharger le fichier
inria-00073107 , version 1 (24-05-2006)
  • HAL Id : inria-00073107 , version 1
Chadi Barakat, Eitan Altman. Analysis of TCP in Networks with Small Buffering Capacity and Large Bandwidth-Delay Product. RR-3574, INRIA. 1998. ⟨inria-00073107⟩
73 Consultations
146 Téléchargements
