Detection Signal Design for Failure Detection: a Robust Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1998
The detection signal is an input signal that enhances the detectability of failure. Assuming that the normal and the failed behaviors of a process can be modeled by two linear systems subject to bounded energy perturbations, a method for constructing a minimum energy detection signal, guaranteeing detection of failure, is presented. The online implementation of the failure decision filter is also considered.
Autre [cs.OH]
RR-3547.pdf (380.2 Ko) Télécharger le fichier
inria-00073136 , version 1 (24-05-2006)
  • HAL Id : inria-00073136 , version 1
Ramine Nikoukhah, Stephen L. Campbell, François Delebecque. Detection Signal Design for Failure Detection: a Robust Approach. [Research Report] RR-3547, INRIA. 1998. ⟨inria-00073136⟩
99 Consultations
232 Téléchargements
