Computational Geometry and Discrete Computations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1998
Olivier Devillers
In this paper we describe some problems arising in practical implementation of algorithms from computational geometry. Going to robust algorithms needs to solve issues such as rounding errors and degeneracies. Most of the problems are closely related to the incompatibility between on one side algorithms designed for continuous data and on the other side the discrete nature of the data and the computations in an actual computer.
Autre [cs.OH]
RR-3533.pdf (191.69 Ko) Télécharger le fichier
inria-00073152 , version 1 (24-05-2006)
  • HAL Id : inria-00073152 , version 1
Olivier Devillers. Computational Geometry and Discrete Computations. RR-3533, INRIA. 1998. ⟨inria-00073152⟩
63 Consultations
152 Téléchargements
