Checking the Convexity of Polytopes and the Planarity of Subdivisions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1998
Olivier Devillers
Giuseppe Liotta
  • Fonction : Auteur
Franco P. Preparata
  • Fonction : Auteur
Roberto Tamassia
  • Fonction : Auteur
This paper considers the problem of verifying the correctness of geometric structures. In particular, we design simple optimal checkers for convex polytopes in two and higher dimensions, and for various types of planar subdivisions, such as triangulations, Delaunay triangulations, and convex subdivisions. Their performance is analyzed also in terms of the algorithmic degree, which characterizes the arithmetic precision required.
Autre [cs.OH]
RR-3527.pdf (269.07 Ko) Télécharger le fichier
inria-00073158 , version 1 (24-05-2006)
  • HAL Id : inria-00073158 , version 1
Olivier Devillers, Giuseppe Liotta, Franco P. Preparata, Roberto Tamassia. Checking the Convexity of Polytopes and the Planarity of Subdivisions. RR-3527, INRIA. 1998. ⟨inria-00073158⟩
64 Consultations
382 Téléchargements
