Periodic Solutions of the Vlasov-Poisson System with Boundary Conditions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1998
Frédéric Poupaud
  • Fonction : Auteur
We study the Vlasov-Poisson system with time periodic boundary conditions. For small data we prove existence of weak periodic solutions in any space dimension. In the one dimensional case the result is stronger: we obtain existence of mild solution and uniqueness of this solution when the data are smooth. It is necessary to impose a non vanishing condition for the incoming velocities in order to control the life-time of particles in the domain.
Autre [cs.OH]
RR-3518.pdf (312.2 Ko) Télécharger le fichier
inria-00073166 , version 1 (24-05-2006)
  • HAL Id : inria-00073166 , version 1
Mihai Bostan, Frédéric Poupaud. Periodic Solutions of the Vlasov-Poisson System with Boundary Conditions. RR-3518, INRIA. 1998. ⟨inria-00073166⟩
106 Consultations
226 Téléchargements
