Long Term Dependences and Heavy Tails in Traffics and Queues Generated by Memoriless on/off Sources in Series - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1998
Philippe Jacquet
This repport presents the analytical study of a surprising case where a denumerable set of independent and memoriless on/off sources in series creates a traffic with long term dependences. We use Mellin transform to characterize the asymptotic behavior of those dependences. We use similar tools to analyse the queue size of a server subject to these sources in series. This architecture roughly models a shared network like internet. We show that the queue size distribution has a heavy tail. These results agree with the recent experimental datas collected on Web activity.
Autre [cs.OH]
RR-3516.pdf (270.2 Ko) Télécharger le fichier
inria-00073168 , version 1 (24-05-2006)
  • HAL Id : inria-00073168 , version 1
Philippe Jacquet. Long Term Dependences and Heavy Tails in Traffics and Queues Generated by Memoriless on/off Sources in Series. [Research Report] RR-3516, INRIA. 1998. ⟨inria-00073168⟩
151 Consultations
129 Téléchargements
