An Extension of Popov Criterion to Multivariable Time-Varying Nonlinear Systems. Application to Criterion for Existence of Stable Limit Cycles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1998
This report deals with sufficient conditions for absolute stability of multivariable control systems. The proposed conditions extend in a simple way the classical Popov criterion to time-varying memoryless nonlinearities. They are expressed in terms of some Linear Matrix Inequalities (LMIs). A weaker frequency domain criterion is deduced, leading to a simple graphical interpretation. The results ensure in general local stability, however, the stability is global for example for linear time-varying systems. As an application, a Popov-like criterion for existence of stable periodic solutions for periodic systems is proposed, using previous results by the authors.
RR-3512.pdf (292.78 Ko) Télécharger le fichier
inria-00073172 , version 1 (24-05-2006)
  • HAL Id : inria-00073172 , version 1
Pierre-Alexandre Bliman, Alexander M. Krasnosel'Skii. An Extension of Popov Criterion to Multivariable Time-Varying Nonlinear Systems. Application to Criterion for Existence of Stable Limit Cycles. [Research Report] RR-3512, INRIA. 1998. ⟨inria-00073172⟩
83 Consultations
104 Téléchargements
