Optimal Shells Formed on a Sphere. The Topological Derivative Method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1998
The subject of the paper is the analysis of sensitivity of a thin elastic spherical shell to the change of its shape associated with forming a small circular opening, far from the loading applied. The analysis concerns the elastic potential of the shell. The sensitivity of this functional is measured as a topological derivative, introduced for the plane elasticity problem by Sokolowski and $\buildrel . \over {\hbox{Z}}$ochowski (1997) and extended here to the case of a spherical shell. A proof is given that : i) the first derivative of the functional with respect to the radius of the opening vanishes, and : ii) the second derivative does not blow up. A partially constructive formula for the second derivative or for the topological derivative is put forward. The theoretical considerations are confirmed by the analysis of a special case of a shell loaded rotationally symmetric, weakened by an opening at its north-pole. The whole treatment is based on the Niordson-Koiter theory of spherical shells, belonging to the family of correct first order shell models of Love.
RR-3495.pdf (519.21 Ko) Télécharger le fichier
inria-00073191 , version 1 (24-05-2006)
  • HAL Id : inria-00073191 , version 1
Tomasz Lewinski, Jan Sokolowski. Optimal Shells Formed on a Sphere. The Topological Derivative Method. [Research Report] RR-3495, INRIA. 1998, pp.62. ⟨inria-00073191⟩
170 Consultations
98 Téléchargements
