On Deletion in Delaunay Triangulation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1998
Olivier Devillers
This paper present how space of spheres and shelling can be used to delete efficiently a point from d-dimensional triangulation. In 2-dimension, if k is the degree of the deleted vertex, the complexity is O(k\log k), but we notice that this number apply only to low cost operations; time consuming computations are done only a linear number of times. This algorithm can be viewed as a variation of Heller algorithm which is popular in the geographic information system community. Unfortunalty Heller algorithm is false as explained in this paper.
Autre [cs.OH]
RR-3451.pdf (271.47 Ko) Télécharger le fichier
inria-00073239 , version 1 (24-05-2006)
  • HAL Id : inria-00073239 , version 1
Olivier Devillers. On Deletion in Delaunay Triangulation. RR-3451, INRIA. 1998. ⟨inria-00073239⟩
85 Consultations
1187 Téléchargements
