Parallelisation of Semi-Lagrangian Vlasov Codes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1998
Eric Dillon
  • Fonction : Auteur
  • PersonId : 756482
  • IdRef : 163597235
Pierre Bertrand
  • Fonction : Auteur
Alain Ghizzo
In this report we describe the parallel implementation of semi-Lagrangian Vlasov solvers, which are an alternative to Particle-In-Cell simulations for the numerical investigation of the behaviour of charged particles in their self-consistent electromagnetic fields. The semi-Lagrangian method which couples the Lagrangian and Eulerian point of view is particularly interesting on parallel computers as the solution is computed on grid points the number of which remains constant in time on each processor, unlike the number of particles in PIC simulations, and thus simplifies greatly the parallelisation process.
Autre [cs.OH]
RR-3430.pdf (147.95 Ko) Télécharger le fichier
inria-00073260 , version 1 (24-05-2006)
  • HAL Id : inria-00073260 , version 1
Olivier Coulaud, Eric Sonnendrücker, Eric Dillon, Pierre Bertrand, Alain Ghizzo. Parallelisation of Semi-Lagrangian Vlasov Codes. [Research Report] RR-3430, INRIA. 1998, pp.15. ⟨inria-00073260⟩
148 Consultations
191 Téléchargements
