Proof Normalization for a First-order Formulation of Higher-order Logic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1998
We define a notion of cut and a proof reduction process for a class of theories, including all equational theories and a first-order formulation of higher-order logic. Proofs normalize for all equational theories. We show that the proof of the normalization theorem for the usual formulation of higher-order logic can be adapted to prove normalization for its first-order formulation. The «hard part» of the proof, that cannot be carried out in higher-order logic itself (the normalization of the system F-omega) is left unchanged. Thus, from the point of view of proof normalization, defining higher-order logic as a different logic or as a first-order theory does not matter. This result also explains a relation between the normalization of propositions and the normalization of proofs in equational theories and in higher-order logic: normalizing propositions does not eliminate cuts, but it transforms them.
Autre [cs.OH]
RR-3383.pdf (224.39 Ko) Télécharger le fichier
inria-00073306 , version 1 (24-05-2006)
  • HAL Id : inria-00073306 , version 1
Gilles Dowek. Proof Normalization for a First-order Formulation of Higher-order Logic. [Research Report] RR-3383, INRIA. 1998. ⟨inria-00073306⟩
87 Consultations
581 Téléchargements
