On the Rates of Convergence of Erlang's Model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1998
Philippe Robert
Danielle Tibi
  • Fonction : Auteur
The convergence to equilibrium of the renormalized M/M/$N/N$ queue is analyzed. Some upper bounds on the distance to equilibrium are given and we prove the cutoff property for two regimes of this queue. We use simple probabilistic methods, such as coupling technics and martingales, to derive our results.
RR-3368.pdf (316.91 Ko) Télécharger le fichier
inria-00073321 , version 1 (24-05-2006)
  • HAL Id : inria-00073321 , version 1
Christine Fricker, Philippe Robert, Danielle Tibi. On the Rates of Convergence of Erlang's Model. [Research Report] RR-3368, INRIA. 1998. ⟨inria-00073321⟩
61 Consultations
1376 Téléchargements
