The Optimal Time-Continuous Mass Transport Problem and its Augmented Lagrangian Numerical Resolution - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1998
Yann Brenier
This paper presents the mass transport problem in its time-continuous formulation and introduces an augmented Lagrangian numerical technique for its resolution.
Autre [cs.OH]
RR-3356.pdf (644.24 Ko) Télécharger le fichier
inria-00073333 , version 1 (24-05-2006)
  • HAL Id : inria-00073333 , version 1
Jean-David Benamou, Yann Brenier. The Optimal Time-Continuous Mass Transport Problem and its Augmented Lagrangian Numerical Resolution. [Research Report] RR-3356, INRIA. 1998. ⟨inria-00073333⟩
136 Consultations
756 Téléchargements
