Problems of Adamjan-Arov-Krein Type on Subsets of the Circle and Minimal Norm Extensions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1998
Juliette Leblond
  • Fonction : Auteur
  • PersonId : 833419
Jonathan R. Partington
  • Fonction : Auteur
We study some generalizations to subsets of the unit circle of Adamjan-Arov-Kr- ein type problems and mainly the one of extending a given function to the missing part of the boundary so as to make it as close to meromorphic with $N$ poles as possible in the $sup$ norm while meeting some gauge constraint. To make our analysis computationally effective, a generic non--multipleness result of the singular values of Hankel operators is established which allows us to provide a convergent resolution algorithm in separable Hölder-Zygmund classes.
Autre [cs.OH]
RR-3335.pdf (459.86 Ko) Télécharger le fichier
inria-00073354 , version 1 (24-05-2006)
  • HAL Id : inria-00073354 , version 1
Laurent Baratchart, Juliette Leblond, Jonathan R. Partington. Problems of Adamjan-Arov-Krein Type on Subsets of the Circle and Minimal Norm Extensions. RR-3335, INRIA. 1998. ⟨inria-00073354⟩
57 Consultations
148 Téléchargements
