Asymptotic Behaviour of Reduced-Order Filters - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1997
M. C. Roubaud
Reduced-order filters are proposed for linear and nonlinear systems and their long time behaviour is studied. Using the results of Ocone and Pardoux \cite{ocpa} on the asymptotic stability of the optimal filter with respect to its initial condition, the asymptotic efficiency of these filters is established in various cases.
Autre [cs.OH]
RR-3311.pdf (390.23 Ko) Télécharger le fichier
inria-00073378 , version 1 (24-05-2006)
  • HAL Id : inria-00073378 , version 1
A. Le Breton, M. C. Roubaud. Asymptotic Behaviour of Reduced-Order Filters. RR-3311, INRIA. 1997. ⟨inria-00073378⟩
36 Consultations
31 Téléchargements
