A Fluid Queue Driven by a Markovian Queue - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1997
Bruno Sericola
Bruno Tuffin
  • Fonction : Auteur
  • PersonId : 830166
We consider a fluid queue receiving its input from the output of a Markovian queue with finite or infinite waiting room. The input rate of the fluid queue is characterized by a Markov modulated rate process. We derive a new approach for the computation of the stationary buffer content. This approach leads to a numerically stable algorithm for which the precision of the result can be given in advance.
Autre [cs.OH]
RR-3306.pdf (232.84 Ko) Télécharger le fichier
inria-00073383 , version 1 (24-05-2006)
  • HAL Id : inria-00073383 , version 1
Bruno Sericola, Bruno Tuffin. A Fluid Queue Driven by a Markovian Queue. [Research Report] RR-3306, INRIA. 1997. ⟨inria-00073383⟩
168 Consultations
104 Téléchargements
