The Analysis of Hybrid Trie Structures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1997
Julien Clément
Philippe Flajolet
  • Fonction : Auteur
  • PersonId : 829512
Brigitte Vallée
This paper provides a detailed analysis of various implementations of digital tries, including the «ternary search tries» of Bentley and Sedgewick. The methods employed combine symbolic uses of generating functions, Poisson models, and Mellin transforms. Theoretical results are matched against real-life data and justify the claim that ternary search tries are a highly efficient dynamic dictionary structure for strings and textual data.
Autre [cs.OH]
RR-3295.pdf (434.04 Ko) Télécharger le fichier
inria-00073393 , version 1 (24-05-2006)
  • HAL Id : inria-00073393 , version 1
Julien Clément, Philippe Flajolet, Brigitte Vallée. The Analysis of Hybrid Trie Structures. [Research Report] RR-3295, INRIA. 1997. ⟨inria-00073393⟩
122 Consultations
221 Téléchargements
