Proving and Computing: a Certified Version of the Buchberger's Algorithm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1997
This paper shows on a non-trivial example that it is possible to mix proving and computing using current technologies. We present a proof of the Buchberger's algorithm that has been developed in the Coq proof assistant. The formulation of the algorithm in Coq can then be efficiently compiled and used to do computation.
Autre [cs.OH]
RR-3275.pdf (301.27 Ko) Télécharger le fichier
inria-00073414 , version 1 (24-05-2006)
  • HAL Id : inria-00073414 , version 1
Laurent Théry. Proving and Computing: a Certified Version of the Buchberger's Algorithm. RR-3275, INRIA. 1997. ⟨inria-00073414⟩
39 Consultations
158 Téléchargements
