Symbolic Asymptotics: Multiseries of Inverse Functions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1997
Bruno Salvy
John Shackell
  • Fonction : Auteur
We give an algorithm to compute an asymptotic expansion of multiseries type for the inverse of any given exp-log function. An example of the use of this algorithm to compute asymptotic expansions in combinatorics via the saddle-point method is then treated in detail.
Autre [cs.OH]
RR-3264.pdf (392.34 Ko) Télécharger le fichier
inria-00073425 , version 1 (24-05-2006)
  • HAL Id : inria-00073425 , version 1
Bruno Salvy, John Shackell. Symbolic Asymptotics: Multiseries of Inverse Functions. [Research Report] RR-3264, INRIA. 1997. ⟨inria-00073425⟩
56 Consultations
138 Téléchargements
