Numerical Analysis of Different Vibrational Relaxation Models for Master Equations. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1997
We present in this report two modelizations of vibrational relaxation processes in a gaz: the Landau-Teller (LT) model and the master equations (ME). We give different models for VT and VV rate constants. We propose an algorithm to solve the equations of vibrational relaxation (LT or ME) coupled with conservation equations of momentum and total energy. Both models are compared on the computations of the flows around an infinite cylinder, at different Mach numbers.
RR-3263.pdf (880.96 Ko) Télécharger le fichier
inria-00073426 , version 1 (24-05-2006)
  • HAL Id : inria-00073426 , version 1
François Mallinger. Numerical Analysis of Different Vibrational Relaxation Models for Master Equations.. [Research Report] RR-3263, INRIA. 1997. ⟨inria-00073426⟩
56 Consultations
574 Téléchargements
