A two-stage robust statistical method for temporal registration from features of various type - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1997
A model registration system capable of tracking an object, the model of which is known, in an image sequence is presented. It integrates tracking, pose determination and updating of the visible features. The heart of our system is the pose computation method, which handles various features (points, lines and free-form curves) in a very robust way. It consists in using robust estimators in a two-stage process: a robust residual is computed for each feature and a robust function of these residuals is minimized. Our method is therefore able to give a correct estimate of the pose even when tracking errors occur. This method is also used to update the set of model features along the sequence, by finding the 2D contours that are tracked when new 3D features become visible. The reliability of the system has been shown on a 300-image sequence of a bridge shot at dusk time, for an augmented reality project.
Autre [cs.OH]
RR-3235.pdf (624.63 Ko) Télécharger le fichier
inria-00073454 , version 1 (24-05-2006)
  • HAL Id : inria-00073454 , version 1
Gilles Simon, Marie-Odile Berger. A two-stage robust statistical method for temporal registration from features of various type. [Research Report] RR-3235, INRIA. 1997. ⟨inria-00073454⟩
153 Consultations
163 Téléchargements
