Characterization of the Singular Part of the Solution of Maxwell's Equations in a Polyhedral Domain - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1997
Franck Assous
Patrick Ciarlet
Pierre-Arnaud Raviart
  • Fonction : Auteur
  • PersonId : 861748
The solution of Maxwell's equations in a non-convex polyhedral domain is less regular than in a smooth or convex polyhedral domain. In this paper we show that this solution can be decomposed into the orthogonal sum of a singular part and a regular part, and we give a characterization of the singular part. We also notice that the decomposition is linked to the one associated to the scalar Laplacian.
Autre [cs.OH]
RR-3226.pdf (228.44 Ko) Télécharger le fichier
inria-00073463 , version 1 (24-05-2006)
  • HAL Id : inria-00073463 , version 1
Franck Assous, Patrick Ciarlet, Pierre-Arnaud Raviart, Eric Sonnendrücker. Characterization of the Singular Part of the Solution of Maxwell's Equations in a Polyhedral Domain. [Research Report] RR-3226, INRIA. 1997, pp.13. ⟨inria-00073463⟩
93 Consultations
213 Téléchargements
