Fast, Optimized Sun RPC Using Automatic Program Specialization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1997
Fast remote procedure call (RPC) is a major concern for distributed systems. Many studies aimed at efficient RPC consist in either new implementations of the RPC paradigm or manual optimization of critical sections of the code. This paper presents an experiment that achieves automatic optimization of an existing, commercial RPC implementation, namely the Sun RPC. The optimized Sun RPC is obtained by using an automatic program specializer. It runs up to 1.5 times faster than the original Sun RPC. Close examination of the specialized code does not reveal further optimizations opportunities which would lead to significant improvements without major manual restructuring. The contributions of this work are: (1) the optimized code is safely produced by an automatic tool and thus does not entail any additional maintenance; (2) to the best of our knowledge this is the first successful specialization of mature, commercial, representative system code; and (3) the optimized Sun RPC runs significantly faster than the original code.
RR-3220.pdf (134.93 Ko) Télécharger le fichier
inria-00073469 , version 1 (24-05-2006)
  • HAL Id : inria-00073469 , version 1
Gilles Muller, Renaud Marlet, Eugen-Nicolae Volanschi, Charles Consel, Calton Pu, et al.. Fast, Optimized Sun RPC Using Automatic Program Specialization. [Research Report] RR-3220, INRIA. 1997. ⟨inria-00073469⟩
180 Consultations
584 Téléchargements
