Calculating tangent sets to certain sets in functional spaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1997
We give necessary and sufficient conditions for a given element to be a member of the second order tangent set $T»_{K}(f,v)$ to the positive cone $K$ in $L^{\infty}¸.$ Since, in general $T»_{K}(f,v)$ may be empty we give conditions on functions $f¸, v$ which ensure that the second tangent set is a cone. As an application of the results obtained we give a characterization of the elements of the first and second tangent set to the set $B={u\in W^{1,\infty}(Ømega)¸ |¸|\nabla u|^{2}\leq 1}¸.$
Autre [cs.OH]
RR-3190.pdf (267.25 Ko) Télécharger le fichier
inria-00073499 , version 1 (24-05-2006)
  • HAL Id : inria-00073499 , version 1
Ewa Bednarczuk, Michel Pierre, Elisabeth Rouy, Jan Sokolowski. Calculating tangent sets to certain sets in functional spaces. [Research Report] RR-3190, INRIA. 1997, pp.24. ⟨inria-00073499⟩
125 Consultations
97 Téléchargements
